sounds like the talk of an elitest who doesn't want anyone else to know about the holy grail. LOL. does the engine not sit further back than the sr. I wouldn't feel special riding around on an sr20 becouse than everyone would know what i was talking about. I would love to start telling people about my 3mm apex seals and bridgeport and watch the look on their face. I know a CA is no 13b but atleast it's not an sr20 that would pull a premium before race wars.knightrider wrote:ok, weight is not that much of an issue, its not that much if any lighter, that weight list floating around is not correct. you can use the ca transmission, you have to remember, the CA came in s13's in japan, everything bolts right up. the KA driveshaft will work, as long as its a 5sp driveshaft. the wiring is similar to the Sr wiring, you just need to splice in the knock sensor wiring from the harness to the block. for intercooler you can use s14 fmic with slight modification to the cold pipe.
and the whole conventional swap thing is just dumb, the motor bolts right in, it might not be popular, but by no means is it any harder than a SR, so there is no special members only jacket or anything.
Modified by knightrider at 4:49 PM 7/6/2006
oh and that comment was me being the pun star that i am.driftin8nez wrote:OK so after weighting all the options i've deciding to go with the ca for my s13. Mainly becouse well it weighted the least hehe. No, but seriously i.....
ok that clears up that.Thanks for the help guysknightrider wrote:you can use a KA clutch on the CA flywheel, the CA uses a 225mm disk, just like the KA, all you have to do is remove one of the dowel pins in the flywheel because it wont line up with the KA presure Plate. and i would like to see you get a KA flywheel on a CA crank, the KA uses 6 bolts, where the CA uses 8.
the transmission is the same between the KA, SR, and CA. only the front bellhousing is different. 5th gear is a little different between them, but not in a good way.
things i would replace, timing belt, water pump, belts, spark plugs and any gaskets that are obviously leaking.
Classic!driftin8ez wrote:I know a CA is no 13b but atleast it's not an sr20 that would pull a premium before race wars.
float_6969 wrote:At least they're searching I guess!
