I'm Confused...Wiring Z32 MAFS on RB20det
blues14
Car: 1995 Nissan 240SX GTS-t
I have the diagrams, but they dont seem to make any sense. The JWT page shows the RED/GRN wire as the signal wire and the White being the 12v wire. Correct me if i am wrong, but doesnt red usually imply power?? I would like advice from someone who has done this please....here is a pic rb20 left, z32 right. [IMG][/IMG]
blues14
I would think the Two sheilded wires, one white, one black connect. then the two remaining black wires get spliced, then i would pair up the red/grn with the last wire being blk/wht. Does that sound about right??
OpeLok
I used this when I did mine and never had a problem.
Z32 connections are marked A to F but only four connections are used when fitting to the rb20det.This wiring diagram is based on fitting a z32 afm to a r32 gts-t.A: Blank offB: connect to Black wireC: connect to black/silverD: connect to whiteE: connect to black with white traceF: Blank off
e = +12Vb = OUTPUT VOLTAGEc = - ground (ecu)d = - Body ground
blues14
Is that considering E is the Red/GRN.....or is E White??
Carl H
see how the wires are in order on the plugs.connect them in that same order, z32 maf pinout is the same as the rb20's.
blues14
GOT IT. The wire colors are just throwin me off.
Got my 440's in, z32 maf and my Carl H rom tune installed.......runs smoother than stock.....THANKS AGAIN CARL H!!
Sky80
Car: '92 240sx Fastback
Once again might as well post this up for people that are searching, and for the visual people...
fly240
Car: nissan 240sx
how about rb25det?.....how's the connection...
RBKIDD
Car: 92' RBsilvia
07' TBSS
hey you do ecu reflashing?
gtrperformance
Car: FULLY BUILT 1989 USDM KPS13 W/RB20DET
The RB25DET is up there........
RBKIDD
Car: 92' RBsilvia
07' TBSS
hey you said that carl h does ecu tuning in your thread on z32 mas wiring in ur rb. i really need help with that please lmk
craz4240
Car: 1995 240sx w/rb20det
the J30 MAFS Plug has different wire colors FYI.
