I got your help when I was about to buy springs or coilovers. Right after that, you disappeared. I ended up buying Stance GR+ Pro coilovers. Not sure if you've seen pictures of my car. Go ahead and check it out. It's come a long way too. Get a Xenon front lip then your good. Next is 5 speed swap for sure.bluejay wrote:Thanks! You have an amazing memory! Yep, I still have the Tanabe's on there.
Is it easy to find part? It's weird that two cars with Bomex rear undercovers popped up in one week. I think it looks even better than OEM rear valances.bluejay wrote:Yep, that is the Bomex undercover.
I agree, I think the Bomex cover looks better then OEM valances too.94_240sx wrote:Is it easy to find part? It's weird that two cars with Bomex rear undercovers popped up in one week. I think it looks even better than OEM rear valances.
ABS plastic just like OEM bumper. It's those thick rubber material that won't get damaged or cracked easily. You will love it for sure.bluejay wrote:Anyone know what material the Xenon lip is made from?
Actually the Xenon lip is made of low pressure Reaction Injection Molded Polyurethane or as most call it urethane.94_240sx wrote:
wmdavis007, that is a good price. I went to Bomex store and it was $230.
Right, right. What was I thinking? OEM isde skirts and rear valances are ABS plastic. Pig nose lip and Xenon lips are Urethane. Thick rubbery piece, and strong enough to be painted.wmdavis007 wrote:
As for me...I like the lip black on my red car but not sure what others think. When I get my car re painted I will most likely have the lip painted but for now I like it as is. My only problem with getting it painted is I scrap the lip a lot and if it was painted it may start looking crappy after a year or so.bluejay wrote:What's the story with the front lip? I see that a lot of people don't paint it. Is that how it is supposed to be, or do people just like the style of leaving it unpainted?
Do what I did to mine. Be creative. Go home depot and buy some good quality thin rubber molding and attach it under the lip. I put Nismo rubber lip on mine though. That way you can replace the molding anytime you want and no need to paint the lip again.wmdavis007 wrote:
Here you go. I think I have a picture from underneath too. I'll post it later tonight if I can find it.bluejay wrote:That sounds like a good idea. Do you have a pic that shows that clearly?
Don't take transmission advice from QV.... he's a little different.onosqv wrote:screw the 5-spd swap, the auto transmission is great
