My story: about 2 years ago I had a machine shop assemble my short block, I didn't know any better and didn't check their work (reputable local machine shop)... Well 1200 miles later, I was cruising down the highway and I started loosing power, give it gas and it just started choking out... Looked behind me and the highway was completely covered by white/blue smoke...
http://www.nicoclub.com/forums/thread-icons/mad.gif....
Fast-forward about 18 months and I finally got off my a** and pulled the engine apart... I then tore it completely down and brought it to another machine shop, they immediately spotted the problem... Ring gap was way too tight! so I had them bore/hone and hot tank the block and I reassembled it this time!
Engine
Bottom End:-84mm supertech pistons (DO clear squirters!)-Pauter rods-Polished and knifed crank-ACL race bearings-OEM oil and water pump-Lightened stock flywheel-All balanced together-Centerforce stage 2 clutch
Head:-All port/gasket matched-No butterfly valves-Slighted ported and polished exhaust ports -270deg 8.8mm lift regrinds (both exhaust cams)-Tomei valve springs-All seals,keepers,retainers, and seats replaced-New timing belt
Turbo Set-up:-Real garrett gt3076r (.63 a/r)-Custom manifold-3" V-band downpipe to 3" RS-R exmag exhaust (no cat)-Synapse 40mm Wastegate with custom screamer pipe -Synapse BOV- Ebay s14 FMIC- KA throttle body (gasket matched)
Fuel/Ignition-SDS em3-4f-1000cc precision injectors-3bar MAP sensor-walbro 255 pump-NISMO adj FPR -300zx fuel filter
Went to the dyno yesterday and made a bunch of pullsMade 280whp at 12psi 350whp at 18psiand finally, with the wastegate at its highest boost setting 380whp and 300 ft/lbs at only 21
and my nasty engine bay
