98_Q45 »
https://forums.nicoclub.com/98-q45-u278123.html
Mon Feb 26, 2018 7:59 pm
Not to interrupt the flow here, but just thought I'd update...was a newbie and kept having issues accessing the site from my phone and ipad...eventually gave up, but now I finally opened the laptop after 4 months.
Anyhow, so the neglected (though only recently neglected, overall in good shape) q45 has finally become the car I wanted it to be. After at least 1200+ in front end/engine fan belt repairs, I was able to drive it from Arizona to Florida last month with 0 breakdown along the way...despite a leaky valve cover gasket that smoked when engine went off (but changed the boots and 4 plugs, and put a little Bardall's No-Smoke...which didn't stop the smoke much but did keep the oil out of the spark tubes and stopped the misfiring).
However, there's still some work to do. Dove into the valve cover gasket today...seems a bit easier than even the v6 Maxima...but still a pain getting thru all the soot and connectors. Rear Suspension needs something, and still no a/c, but seen a site that has the a/c compressors with the drier for $145 online (if I should avoid, someone let me know). I think the neglected oil leak may have caused the compressor to grind and leak and...idk but it doesn't even have a belt on it so won't even try to figure it out.
Hopefully I can assist anyone who needs advice as well...
