tkeskic »
https://forums.nicoclub.com/tkeskic-u33292.html
Tue Jan 02, 2007 11:10 am
Well, I put the Dunlop M3s on the car, and I can say that the pulling is still there, but its much less on the bad roads. However you can tell that the tires handle different that than RSA. Not sure if its becauyse its a winter tire, or just because of the way this one is made;
what I notice is a softer ride, almost a little floaty in corners (like it sways back and forth a little, loose feeling)The verticale load seems more stiff, ruts in the road translate more into the steering, the biggest change seems to be in "side wall" as it seems to be that floating/soft feelign when turning.
I have to admit I like the feel of the RSA from good year better, I didnt mind the pulling, but thats likly because I was use to it.
In my summer tire, I will be looking for that stiff, tire that doesnt feel like it floats/sways in the corners.
I can see how others who have swapped out for other tires believe the pulling is gone afyer changing tires. Its hardly noticble now, but the other effects it has are not desirable to me. I'm going to be looking for a tire that offers that same feel as the Goodyear RSA did, but a better traction tire, likly a run flat as thats got a great side wall!tk
