drftsil8ty »
https://forums.nicoclub.com/drftsil8ty-u17226.html
Fri Aug 12, 2005 3:10 am
easy,
1.) clutch in when you start.
2.) clutch still in, select gear
3.) let off cluctch slowy, while giving the car gas at the same time. should be the same amount for each pedal.
4.) your in gear, shift to next gear, clutch in, select gear. repeat 3.
taking turns
clutch in, usually you take intersection turns in second...but thats just me.
thats it.....easy
takes some time to get used too.
post if any problems
