Awesome that explains alot . One more question. i dont have a nipple on my hot pipe, but i do have a nipple on my intake pipe, will the intake pipe work? or can i run it to my intake manifold?exhsturbine wrote:yes it is absolutely crucial you use your wastegate. while a "boost controller"'s title states that it does control boost, the actual component which controls boost is the waste gate. a waste gate, such as the one on your t-25, relies on vacuum and pressure. take a look at your wastegate actuator. you will notice the vacuum line plugged into "a circle" from there an arm is connected to the turbine housing. inside the housing is a "door" this assembly is crucial to controlling boost. inside the circle is a spring, which requires a certain amount of pressure to compress. (obviously the pressure is from the turbo) when the circle fills up with air and the spring compresses, which is connected to the arm, the amount of pressure will move the arm opening the door. which in turn releases exhaust energy before it spools the turbo. ok? haha so now if you understood my screwed up explanation.... the stock spring from what i understand, is set at 7lbs. so what the boost controller does, in effect is, lie to the wastegate. now you could of course buy a different spring set at say.... 14lbs, but of course thats not adjustable, or a wastegate with an adjustable rod. but back to your question....
you need both connected! run a v-line from the hot pipe to the boost controller to the wastegate. on a manual one, tightening the screw increases the boost while loosening decreases. the controller may receive 14 lbs of boost, but its job is to tell the wastegate its getting less. hahahah make sense? i hope so. cause im so tired i can barely type good luck!
i believe that on the stock system, the boost control solenoid, and boost pressure sensor(or in your case, your manual boost controller), both received their 'signal' if you will, from the manifold, so if it was good enough for nissan it should be good enough for you. but that isnt the way that i do it for reasons that idahotuner explained. i look at the tubing as more space for boost to run off to away from my engine, the less space the better. and like idahotuner said, you cant do it off the intake.prizzom wrote:Awesome that explains alot . One more question. i dont have a nipple on my hot pipe, but i do have a nipple on my intake pipe, will the intake pipe work? or can i run it to my intake manifold?
i may have said vacuum once, but i also said pressure, meaning boost, which is what i was focusing on. and it is better to have the nipple on the hot pipe for better response in the system, as its closer. however, ive always wondered if it wouldnt be better, to put the wastegate signal on the cold side, to account for any pressure drop in the charge air system, for a more accurate reading on how much boost is actually reaching the manifold.idahotuner wrote:no. he is using the word vaccum when he should be using the word boost. it needs to be off a part of the pipe that has boost pressure. so any of the intercooler pipes not the intake pipe or manifold.the hot pipe is good because it will give you more control with your boost controller. because the vacuum lines are shorter
