I love Tuning! Dyno'd the Ca!
char6310
Car: 90' 240sx Ca18det
Hey everyone, Just got back from the dynojet...pretty pleased with the results...here is a list of my mods...ca18det, s14 t28bb turbo, 440cc injectors, s-afc, z32 mafs, apexi filter, FMIC, Uras 3" catback, 3" downpipe, Greddy type s bov (recirculated)...etc.
Anyway, on Runfile 01...that was my first run without any "real" tuning to the safc, which put down a decent 229.87 rwhp, but the a/f wasn't even on the chart...haha.
By Runfile 04...we had the a/f ratio down to a respectable 12:1 (approx) and pulled a new number of 246.65 rwhp.
Both Runfile 01 and 04 were on 15psi...and timing was at 12 degrees btdc to be safe...you will also notice that my power was still on the increase, but he only ran it to a little over 6k rpm (still had more power to gain...err, haha)
On runfile 06 we bumped it up to 17psi and put down 256.68 rwhp, not to bad. Here are some pics of the dyno and the dyno sheet...
enjoy and by the way, i am open to comments....thanks!
char6310
Dyno sheet...
char6310
Close up of Dyno Numbers....
8ggalant
Car: nissan cefiro
NICE
ca18detizzle
Niiice! im looking at the same setup.. pretty impressed with the safc...
c-rad
Car: 1991 Nissan 240SX w/CA18DET
6k??? man, run that thing to 7500!!! Numbers look pretty good though.
RMiller
Car: BBQing
Great numbers. Maybe that's about what I put down.... What was timing set at for the best run? 12 btdc is pretty retarded. Why didn't you advance the timing and instead raised the boost?
Modified by RMiller at 10:09 PM 2/21/2005
char6310
I ran it at 12 btdc just to be safe... I think that if i would of ran it at 15btdc I would of gotten more horse....I will possibly change it sometime, but the car seems to like it where it is at the moment...overall, i didn't want to blow up on the dyno...haha, i used this more for tuning the safc, and less for numbers...but i feel i still got both...
biosehnsucht
keep in mind fixing the timing will make the tuning you did on the safc now obsolete and you'd have to do it again to be safe.
char6310
yea, true...good point...I will most likely leave it where it is considering she is running like a champ, and still pretty damn fast...
c-rad
Also to note, the torque curve is nice and flat.... Good job once again...
float_6969
Perfect dyno curves man. Looks just like it should. Were those the measured numbers, or the corrected numbers?
Turbogixxer
Rev it higher, your torque has not fallen off yet.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
12bdtc my car would be slugish as hell , and run duper high EGTs hmm
char6310
By the way, these are measured numbers...
sil_eightyRPS13
Car: 1989 RB27 cefiro
hmmmmm.....numbers should be a bit higher at least 270hp range i was able to get 227 rwhp out of my silvia with a SRt25 my mods only included a GTR fmic, hks intake, 3inch exhaust with stock down pipe not cats.
looks good keep up the tuning it should get better.......
