72nismo wrote:Ok I finally got a stock muffler.Just came from muffler shop and they told me that the muffler will not make my Murano sound diffrent.They also showed me that the Murano has a second large muffler in the middle.They said maybe if u take that off it will make some noise. So now I am totally confused. I will go get a second opinion tomorrow. Now in regards to mid pipe on Murano I am not sure if it has one. Any one know?
If you take that muffler off, it will sound different.
The trick is that you want it to sound the same or similar as another vehicle.
Not familiar with the Murano. However on many vehicles the large so called muffler is often referred to as a collector. If you have a v6 or v8 then the exhaust flows from the engine and then comes together in the collector and then out to a muffler and then maybe to a resonator (or two). On a true dual exhaust system then this doesn't fully apply (the collector). Many will do what is often referred to as a Camaro dual exhaust system. With this you will take the output from the collector flow it into a muffler that flows out to two exhaust pipes (or resonators).
Change any of this and you will surely have a change in sound. The best bet is to try to duplicate as much as you can of the target system, but there are so many other variables besides the exhaust system itself that you may not get the exact results you desire. In that case you may want to get a water proof speaker and record what you want it to sound like and play it back as you go down the road.
Perry
