pauliedrft »
https://forums.nicoclub.com/pauliedrft-u107784.html
Sat Jan 31, 2009 2:42 pm
Make sure you have access to a vise and air tools but as i stated before 7 hours in the snow and a cold garage . 14mm, 17 mm, 12mm , i think 15 mm but its easy man i had help seeing it was my first rear end job (got my cherry popped on it ) but make sure you put everything back the exact way it came out the shims and all , make sure you do a mesh test get some light coloered grease put it on the ring gear and rotate your diff and see where the grease goes wipe off excess and repeat process ,shine a light in there to see if grease is spread through out all the gear teeth evenly and you should be good we did this to mine because its a 1991 it should be checked . And i had to drop my rear sway bar
