i love my ca,but....
CaEric
Car: 91 Sr Pwred Coupe
i love my ca...but what do i need to take out a stock wrx...with a ****ty driver...?i know this sound like a dam noobie question/......but i realy need to know ?i have :sr : t25dsm 450fmic catback andsafc 300z maf
edited by float_6969 for incorrect usage of butt
Rookieca18det
Car: 93 hatchback (ca18det)
you spelled BUT wrong...twice.
asher4857
Car: '89 240SX Fastback
^ exactly what i was going to say..
float_6969
CaEric wrote:i love my ca...but what do i need to take out a stock wrx...with a ****ty driver...?i know this sound like a dam noobie question/......but i realy need to know ?i have :sr : t25dsm 450fmic catback andsafc 300z maf
S15 SR T28/GT28R550cc injectorsO2 pipe and 3' DownpipeECU burn to remove boost cut/speed cut/rev cut and adjust for injectors and mafs18-21psi (don't run 21psi on this turbo regularly, as you will toast it, but occasionally is fine)Dyno tune w/SAFC to fine tune fuel curveGood driver, because if that WRX comes off the line well you're gonna have some work to do catching up.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
A stock WRX??? You have enough to beat him with what you have. Stock WRX's are only rated at 227 crank HP and they weigh a good bit more than a 240. The mods Float posted would be good if you were racing an STi. But stock WRX's are a joke.
CaEric
Thats what iam saying....."but" they have all the heavey *** fwd ****...it has to weigh a ton.............i was piss *** drunk when i posted this this morning !!!
nocwage
float_6969 wrote:S15 SR T28/GT28R550cc injectorsO2 pipe and 3' DownpipeECU burn to remove boost cut/speed cut/rev cut and adjust for injectors and mafs18-21psi (don't run 21psi on this turbo regularly, as you will toast it, but occasionally is fine)Dyno tune w/SAFC to fine tune fuel curveGood driver, because if that WRX comes off the line well you're gonna have some work to do catching up.
That would take an STi..My T3 setup takes down STis and I don't think it would even be as powerful as what you posted.. (did it with only 17psi of boost on a super-60 and no dyno tuning)
WRX aren't that fast once they are rolling, a stock SR can take a WRX out so I'd guess that CA with an SR turbo and 10psi of boost should be able to do it as well.From a dig your only disadvantage is the instant grip those cars have, once they start rolling they aren't all that fast so you'd quickly overtake him..
I also own a Spec-V, and my buddy with the STi that I raced used to own a WRX, from 120-160km/h he couldn't pull away from my Sentra, and it only has 175hp and weighs more than a 240sx.
float_6969
Yea, I'm retarded. Somehow I read wrx and thought STi, don't ask me why.
A stock WRX shouldn't be an issue to beat with your current mods.
themadscientist
Never seen a WRX that was much of a challenge. Hell, I bet even an SR20 could smoke one.
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
I should could take a dump right now! Whats a WRX??
ILOVESILVIA(S13)
JK, obviously!
Ca_laurier
i just had a t28 on my ca18 and i pulled just as hard as a wrx. this was only at 8 psi
you can easily take one
