Let me see if I have this straight. You have a motor that has been fully built likely to the tune of several thousand dollars, you have over a $1000 hanging off the back of it in that twin plate and you say screw the vendor? That doesn't make a whole lot of sense to me. You did screw them, the parts and work you have identified so far alone are worth more than you probably paid for it. Would you have been happier with a tired clogged up unopened motor that needed a rebuild immediately?Robert90sx wrote:What kind of abuse has this motor seen. Screw Nagasaki Motors.
clean block and head...300 bucks...?float_6969 wrote:LOL, you don't have a short block lying around there too do you? Maybe one without a crank or pistons or rods? I kinda want one.
HKS is the only company that stamp their trademark on the camshaft itself. Look at the transmission side of the camshaft for numbers. If there are some, let us know what they are and we may be able to help you determine what you have one way or another. As for the cam gears, those are old school HKS units. You may want to check the compression before you go any further because when engines have add-ons like that, they've been raped and sometimes over-boosted which will lead to cracked ring lands and/or all types of other issues. Other than that, good buy .Robert90sx wrote:I thought I would give this a little update.
I finally got everything put together. Time to start it. I never pulled the head or valve covers hoping for the best. I cranked her over and the motor tried to fire, actually spun over a few times, but sounded like my timing was way off. I figured I would take a look at the timing belt to insure that it has not slipped off a tooth. To see my self looking at this.
Who makes these? There are no adjusting marks, and don't know what to think.
After looking at the cam, it looks brand new and would love to figure out if this is after market as well. Any identifiable marks on it I can look for?
Been around along time my friend and am no stranger to the trickery of this business. That engine was dogged by someone here in the U.S. that blew the engine and swapped for an SR. Usually when the turbo is gone, the importer is the swiper. Automatic CAs are better and are usually the higher compression CAs.Robert90sx wrote:Dee said it best
"You may want to check the compression before you go any further because when engines have add-ons like that, they've been raped and sometimes over-boosted which will lead to cracked ring lands and/or all types of other issues."
I am going to pull the cams, and possible the head today. I have taken the red pill, I want to see how far this rabbit hole goes.
I wouldn't mind selling mineca18detgabby wrote:Ive always wanted some HKS cam gears, but never can find them.
