DAEDALUS wrote:You advance your timing if you're going from 15 to 17 degrees before top dead center, not 15 to 13. You're advancing the spark relative to the #1 piston top dead center--the spark will happen sooner. When you talk about "timing" everything is relative to the #1 piston tdc . Everything else can change...cams, sprockets, spark, etc.
