masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Mon Sep 13, 2004 5:51 am
LOL @ SpongeBob and DawgMode. Good one guys. What you're saying is "Well, you narrowly beat out a D16 Civic, so you should definately throw MOST of your present setup out the window and throw down thousands of dollars to install a turbo kit." I ask, do you guys need a turbo to beat a stock Civic? No... I have mildly tuned my car similarly to K240 and most of the time, I have no problem being first across the line.
What's interesting to me, K240, is that you started to pull on him in the late gears. Theoretically, the very opposite should happen: you should jump him on launch and then, if the Civic were to pull at all, it would be later, in second or third gear.
If you have been experiencing a loss in power, you definately need to have that addressed. When was your last tuneup? Oil change? You know, I had a similar problem a while ago and it turned out to be the EGR valve. You may want to have that checked, along with your MAFS and vacuum lines.
Good luck.
