I lost my keys .. (I know.. I know)
bcuz
I know, Im a dumb *** ect ect..
but what can I do? I dont have any copies, my doors are locked, and the weather stripping on my car is kinda old so its stiff, so I cant seem to get anything down there...
My brother told me that honda can make keys with a vin number, can nissan do this too? (I would just call but today is a holiday..)
also I know that my key starts my freinds nissan pickup, so Im assuming his key would start my car, but I doubt it would open the doors. My ignition is worn down, I can take my key out and put it back in while the car is running. So I guess Ill try and figure out a way of getting in the car (without paying a locksmith 50$, or breaking a window) and use another key for now without locking my car, then go to nissan when they are open and see if they will make me a key?
BTW, its a s13
180fan
Car: 89 fastback
do you have a friend with AAA? they can call AAA and AAA can call a tow truck, they can pop your door open. Then check the glove box, there should be a sticker with the key code that you need. You should be able to make a key with that number.
navysnail
try the pickup first, it may work
if not, 180fan hit it on the head
Shift__BODOM
Car: 1993 240SX Hatch
if youre locked out, you can get in with little hassle with a coat hanger. if you have a hard object thats maybe a half inch wide, then this will work. get the glass, and pry it back SLOWLY from the top. insert this hard thing between the body and the glass so the glass is now propped open. get your coat hanger, bend it accordingly, and slip it into the driving compartment from the rear of the window. hook the lock, and pull quickly. once the lock is popped, just open the door and let the prop fall into the seat. i have to do this all the time, and i use a lighter to prop the window open.
good luck!
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
someone plz delete that post, i do not need anyone knowing how to break into my car. if you wanted to tell him you shouldve pmed/mail/aim'ed him about it, not tell thousands of people how to break into our cars....
