LOL - I consider myself smart for the most part!! And no, the cable wasn't faulty, the connector to the post was just a bit deteriorated.Dattebayo wrote:
Replace the cable first, smart guy. Don't skip steps! You're the one who said the cable was faulty, do it right! For once don't follow the standard 240 cheap-*** method and get it all done the way you would expect a professional to do it!
Also, Wal-Mart will probably just charge the battery you get from the junkyard and send you packing. Once again you are doing it wrong!
And I know its good because I grabbed it off the shelf and took it home to set on trickle charge for a few hours. . .
And I'm honestly done with cheaping out. I figured if I've already put X amount of money into it, it won't hurt to get it quality grade and right the first time!!
