I know this is on here but....
silfortysx719
Car: 2011 juke 26080 miles
I cant find an answer to my question my hids on my s13 wont work i have high lows (not bi xenon) and my regular bulbs work but when i put these in nothing just the highs work not the hid part yes they are hooked up correctly so any ideas???? :gotme :gotme :gotme :confused: :confused:
rsmithdrift
Car: 1993 240sx fastback se.
silfortysx719 wrote:I cant find an answer to my question my hids on my s13 wont work i have high lows (not bi xenon) and my regular bulbs work but when i put these in nothing just the highs work not the hid part yes they are hooked up correctly so any ideas???? :gotme :gotme :gotme :confused: :confused:
I've been researching HID setups alot lately since I'm looking into it for my car. I've learned their are many options...
Did you get the Kit from ebay that has the H4 plug in to the harness for plug and play-ness and has a HID low beam + halogen high beam??
silfortysx719
yeah and it does have the actual pig tails not the female ends you just stuck into the h4 connector
rsmithdrift
well... in that case they should just be plug and play and work when you turn your low beams on...
Maybe defective?? Do they both not work?? If so I would check that you are plugging them in the right way and I would check that the way it's wired is correct for the way the plug is wired. ie the high beam for the high beam the low beam for the low beam and the ground for the ground.
silfortysx719
yeah they are wired right and they arent defective because i put them in my versa to see if they were and they worked on my versa im hella puzzled :facepalm:
alms24sebring
'04 Nissan Sentra SER SpecV
dam. well if they worked in the Versa they should work in the 240. (2+2=4) You have to be doing something wrong here. Maybe a wrong sized/blown fuse or a relay that isnt working right. That or you are wiring it wrong seems to be the only possible options
silfortysx719
lol checked all the fuses and swapped out relays and still nothing i give up lol the only thing i can think of is the light switch ive been hearing a lot lately the light switch can cause this but i cant find one locally
silfortysx719
yup replaced the light switch and they started working
rsmithdrift
silfortysx719 wrote:yup replaced the light switch and they started working
Hell yeah. Pics????
