longtooth »
https://forums.nicoclub.com/longtooth-u152752.html
Sat Jul 31, 2010 8:28 am
FS5W71C Transmission 4.25 pt (US)
FS5R30A Transmission 5.125 pt (US)
Differential Carrier Gear Oil
Rear: H190A 1.5 liters (3-1/8 pt)
C200 1.3 liters (2-3/4 pt)
H233B 2.8 liters (5-7/8 pt)
Front (4WD): R180A 1.3 liters (2-3/4 pt)
R200A 1.5 liters (3-1/8 pt)
Fluid - M/T
Fluid Type API GL-4 This is the transmission fuild.
Fluid Viscosity SAE 75w-90 Or 80w-90
This is the differental fuild.
Standard differential gear API GL-5
Limited-slip differential gear LSD) *API GL-5
*Note: Use only LSD gear oil API GL-5 and SAE 80W-90 approved for Nissan LSD. SAE 90 is acceptable in ambient temperatures above -18°C (0°F).
Hope that helps you out.
