miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Fri Mar 26, 2010 9:47 am
i took some pics when i took apart my door to lube my window tracks cause they rolled down extremely slow, but these should help
this is from the drivers side door cause i didnt take pics of passenger, same thing on both sides.
Step 1:
Step 2 ( Be careful taking this off, i had to superglue on of mine back together :
Step 3: ( Pop this up between where im holding my finger, once it pops up a little grab it up front of the buttons where this peice ends and pull on it.
Step 4: Unplug those connectors
Step 5: there will be a screw in that little pocket in that arm peice then you pry it out or pull on it, then take out those green screws screws you see on there.
and then no you dont need a panel popper i never use one, just run along the edge of the door slowly with your fingers and pull around the clip when you come close to one and you wont break anything, key is not to do it fast.
and heres how it looks with the panel off
these arent the best pics but i didnt intend to make a guide out of them, should help you out most of the way though.
