Clipsed »
https://forums.nicoclub.com/clipsed-u53627.html
Tue Jan 30, 2007 6:34 pm
Here, this is what the manual says about testing that feature! lol
INSPECT THE FUNCTION OF THE ANTI-PINCH SYSTEM1. Fully open the door glass.2. Place a wooden piece (wooden hammer handle, etc.) near the fully closed position.3. Carry out fully closing operation with auto up switch. Check that the glass reverses without pinching the wooden piece, is lowered approx.150 mm (5.91for 2 seconds and then stops. The glass should not be raised with power window main switch while it is reversing or lowering.CAUTION: Use care to avoid being pinched during the inspection. Do not use a hand, etc. in place ofwooden piece during the inspection. Check that auto up function is normal before inspection, following the system initialization.
