Imissmyturbo wrote:Putting a 4 or 6 puck clutch in with a stock pressure plate is a DSM trick to get a clutch that holds power but is cheap and easy to drive. If my car was a race car I would have stuck a heavy duty pressure plate in. I still have it incase this setup starts to slip but I want to see how this holds up.
**** if i was gonna go through all the work of pulling the trans, just spend a couple hundred bucks and get a clutch you never have to worry about.Imissmyturbo wrote:Putting a 4 or 6 puck clutch in with a stock pressure plate is a DSM trick to get a clutch that holds power but is cheap and easy to drive. If my car was a race car I would have stuck a heavy duty pressure plate in. I still have it incase this setup starts to slip but I want to see how this holds up.
