Q45AZ wrote:There is no power to the car itself but a clicking noise coming from somewhere on the passenger side of the motor. Im not sure what else i can say so any help would be great. Thank you.
I'm confused as to whether you've started and driven your Q or if you had it towed home when you bought it.
There's a blue starter relay tucked away in the passenger side corner next to the firewall (below the wiper motor?). If it's making the noise temorarily swap it with the blue AC relay in the engine compartment fuse box for now.
I'm not sure what to tell you about the missing security relay or what affect it could have on starting. Here's a link to to a 94 FSM. For what you're checking it will be the same as the 91. Location of electrical units starts on page EL239
http://www.nicoclub.com/FSM/Q45/1994_Q45/
Are you getting interior lights and music or no power at all? If you have interior lights could the clicking noise be coming from the starter (solenoid) below the engine where the engine meets the transmission? If you are getting only clicks when you turn the ignition but have interior power check the battery clamps and connection. They corrode, wear out and sometimes fail to provide a solid connection. Let us know.
By the way welcome to NICO.
