robbbby wrote:There is only one brake booster hose. detatch the hose from the big black thing behind you brake master cylinder and pour it in there.
You don't even really need to pour it in there, the booster is seeing vacuum so it kind of sucks it up like a straw. When I did mine, the car started to sputter and almost die, but I gave it a bit of throttle and it finally settled in to an idle of sorts, and then eventually a normal idle.
FWIW, I used 1/3 of a can in the fuel tank, 1/3 in the oil and 1/3 through the brake booster.
