I just did a sick mod. 200+HP over stock, bolt in.
sommmatt
Car: 1989 Nissan 240SX
Sup.
Hemifan
Car: 2007 Dodge Charger R/T, In the market for a hatch
Yes. Build thread coming???
slidestyle69
Car: 92 s13
5.3 truck motor with lsx bolt ons?
sil80_chris
Car: 1991 Nissan 240sx
You lucky s.o.b...Which LS motor is that? i suck at identifying them.
zach-Ka
Car: 1990 240sx (SR)
Oh snap!!!!
sommmatt
The motor is a 5.3L Aluminum Block from an 06 Envoy, it's actual engine code is "LH6."
4.8L Pistons for high compressionPatriot Stage 2 Heads milled to 59ccLS7 LiftersHardened PushrodsDouble Roller Timing ChainMagic Stick 3 CamLS6 Intake (LS1 Intake pictured)50lb injectors/Walbro 255lph PumpPorted Throttle BodyCustom LongtubesDual Exhaust, no mufflers, no cats.
Built 4L60E until I can afford a T56 High Stall Tq ConverterSteel DriveshaftStock VLSD
Should rev out to 7500RPMs and be making power up there too!
Goal is 450WHP N/A
sommmatt
Note... motor pictured is stock block with truck heads held on with 2 bolts and intake placed on top for mock up. Transmission not in yet but I figured I'd post the pic for fun.
Cbus240
Car: 89' 240sx SR20DET
slidestyle69
Car: 92 s13
very nice sommmatt. are you not going to upgrade the valve springs and retainers?
I'm in the process of doing the truck motor into an s14
and kudos for going with the Al. block.
sommmatt
Heads already have dual gold springs and Ti Retainers installed.
Also the important one... ARP rod bolts.
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
GM is the new sr these days
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I have the same lifters and cam. Injectors are on the large side, you can boost to 8lbs on those.
450 should be easy to get, I'd suggest a 3800 stall
sommmatt
TJG wrote:GM is the new sr these days
I got bored of turbo 4 bangers, decided a lighter engine with tonnes of power under the graph and pistons that didn't need to be warmed up for 20 minutes would be awesome.
OutToWinPAHC wrote:I have the same lifters and cam. Injectors are on the large side, you can boost to 8lbs on those.
Free injectors, I'll cram em in! Tuning will be interesting :P I've been following your build since before I built my KA.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
5.3's are so cheap these days. When I build a new motor I am going for a 6.0 iron block. 13.5:1 compression.
Get an oil cooler on her, it will help a lot, and run some serious fans if the hoods not vented.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Oh tuning for the injectors will be easy, I run 37/42's which is big they edit duty cycle.
And my aftermarket BBK throttle body didn't clear my hood. I way sell it if your interested. It's an 80MM which pairs well with the LS6 intake you have,
sommmatt
I've got a lot of remnants from the KA build including a huge rad + ridic fans. The snail made tonnes of heat @ 30 PSI. I'll probably hack a hood up for track use, as well, I do have a couple of em.
Oil cooler would be an idea, I'm hoping to be dry sump before the end of the summer though.
And I did get this 5.3 for 300 bucks from some shady nig nog in Detroit. Booya. 74000 miles, he even showed me the stolen odometer.
Caveit77777
Car: 1996 240sx SE
Idk why I think this but did you have a "397 hp ka24e"? Could've swore that was you. Just trying to match people up with cars.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
win.
what kinda footwork does she have?
hockeyhelmet0727
Car: 95 zenki se
im not too keen on truck motors at all but could you do a 6.0 turbo doiesel in a 240 lol.
anti_flag_army
Car: 91 Miata, 90 240sx coupe
hockeyhelmet0727 wrote:im not too keen on truck motors at all but could you do a 6.0 turbo doiesel in a 240 lol.
hahahahah pssst you have a 240sx, i wonder what else they put that ka into...
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Its an engine, that is put into truck.
