I can thread the head stud into the block, but once I try to torque the bolt, the bolt will continue to thread but the stud will come up making it impossible to torque it properly.
I know I could take the head off and helicoil it, but that is a total PITA.
Is there anyway to fix this with the head still on? I was thinking about trying to clean up the hole by wrapping a rag soaked in brake cleaner on the end of a rod and then installing the stud with Loctite.
Would this hold or do I have to do it the hard way? Removing the head on this car is much, much more work than in a Nissan...
