I Just Bought A Really Neglected Q45 *Help?!*
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
szh wrote:
gwoods wrote:I suggest a 50% fluid change to start out.
Drain all the fluid into a clean catch container.
Change the filter.
Put 50% of the old fluid back in + 1 bottle of Lucas and 50% new fluid.
Ummm ... when you drain an Infiniti Q45 transmission (i.e., without using a powered flush system like a B&G that cycles the gears), then all you get is about 50% to 60% of the fluid out in the first place. I.e., there is no need to "put 50% of the old fluid back in" as far as I know.
The presence of a dark transmission fluid usually means it was never looked after ... :(
My suggestion echoes Jesda's. But if a simple drain and fill does not improve the situation, you have a dead transmission. You will need to rebuild or replace it ...
Z
That is true the torque converter holds a bunch of fluid when you drop the pan. With that many miles and dark fluid you want to keep from changing all the fluid. Some form of transmission addative is a great idea I like the lucas products.
Automatic transmissions are not that scary. Take everything out in order replace clutch packs and steels put everything back in the reverse the disassemble order. Most are held together with snap rings that are directional, meaning they have an up and down side so make sure you put them in the right way. I had to buy a digital micrometer when I rebuilt mine so I could figure out which snap ring was which.
I upgraded the clutchs using a SUNCOAST kit that feature KOLEEN steels and red frictions. The next day cylinder #3 came apart so I got to rebuild the motor too, well thats nitrous for you.
clouhd_nihne
Car: 1990 infiniti Q45
well its up for sale. I'm going to try and fix this but I'm pretty sure it just needs a new trans. not only that but working on cars where I live is not allowed:/ I should not have bought this car:) lol
gwoods
Find a cute boy who works on cars. Smile at him have him fix your car at his place. Break up. jeeze do I have to think of everything?
clouhd_nihne
I live in ocean shores...there are 30 people in my graduating class!:/ and if i was able to find a cute guy who wants to work on my car, i wouldnt want to break up with him lol:)
clouhd_nihne
soo did the trans fluid/filter change on my car (used lucas trans fix stuff) -shifts WAY better than it did before, and cleaned the air filter in it and now it doesnt even run rough:) its like a completely different car....Thank You Everyone!:))
Razi
Car: Moo
Glad to hear the car is improving!
sbird1
Car: 2006 BMW 325i
Still selling it?
clouhd_nihne
not at the moment, but i can let you know if i decide to any time soon:)
