I just bought a JDM Turbo kit..................
eddie_atryd
Car: 1993 Nissan 240 SX (KA24DE Engine)
I have 93 240 with the KA24DE engine and recently bought a turbo kit, the kit comes with T3 turbochargermanifold 600 x 300 x 76 mm Bar and Plate Intercooler + Piping, 38mm Wastegate Greddy Type-RS BOV Boost Controller Gaskets and Bolts..................... what would be the ideal Fuel management system and what other items would i need to complete the kit before i take it to get it installed please help i know to little about what is all needed!!
Florida240sx
Pics of the kit.....sound slike SSAC crap so therefore you just wasted your money except for the FMIC.......
whiterps13
Car: white LE hatch
Nah dood, its JDM so it must be kwality...
Florida240sx
JDM turbo kit on a usdm motor........enough said
chrislis
Car: 1998 240sx sE!
hey.
i'm rocking the SSAC and XS powah.
and im boosting 10 pounds all day long on stock internals. performs wonderfully. and it will be even better with an FPR. but don't knock it.
we also resurfaced the manifold and such.
TOPSECRT88
Car: S14
Hopefully its not SSAC. That SSAC sh*t is the biggest waste of money....I can't belive people still buy that cheap crap. Im sure most of you have seen the pic of an SSAC Turbo basically "glued" together. Garbage.
gaehrings13
Car: Nissan S14
Hey I have a ssac kit...... but not the turbo it was gigantically HUGE. I got a on-center master power turbo. It works good i've had it on since march and its still running good. (note piping was done by me not ssac )
irax
Car: VQ35DER Powered S14.3
a FPR and a SAFC and you should be good to go... personaly i wouldnt use the turbo or manifold. You can have the manifold reinforced and welds done correctly but at that point you can buy a nice cast (cast iron, or tubular) manifold.
shockload
Car: 240
i ran an xs power 50 trim at 25 psi and it smokes at idle now
Florida240sx
I wouldn't trust their turbos/ wastegate. Manifold you can prep and make it last, but why go through that work??? Unless you got the tools handy.....
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
I have always wondered about these kits and their reliability. I think everything but the turbo would be OK to use, more people who are using XS Power and SSAC should chime in.
BobWithBoobs
Car: 89 couple with s14 dohc swap.
haha
shockload wrote:i ran an xs power 50 trim at 25 psi and it smokes at idle now
i dont know it made me lauph
sunnys14
Car: S14
cheap turbos dont last. youll get shaft play and and bad turbo seals.
cheap wastegates dont last. youll get unstable boost and boost spikes.
please dont ask me how i know...
babowc
Car: 240sx
i thought ssac manis held up fine if you just braced a bit.the t2 series mani seems to hold up fine by just slotting between the runners..t3/t4 series mani requires some bracing..
im sure its no comparision to manifolds made by real quality shops, but then again, its very *cheap*
KATwo40
Car: 1993 240sx KA-T
I've been running the SSAC T3/T4 topmount tubular mani for over 2 years now (about 25k+ miles) and no cracking. First time around was with a TD04H-13C (small turbo) and now with a T3/T04E + 38mm Tial gate for the last few months.
So far, no drama with the manifold. I just put a flex section in the downpipe and called it a day. No added bracing or anything like that.
Chezedik
Car: 1991 Nissan 240sx
I have a friend running it on his RSX with nothing but good things to say. I have to admit, I was skeptical after all the trash talk I have read, but I would buy one now. If I didn't already have Garrett...
