bbdaines »
https://forums.nicoclub.com/bbdaines-u18045.html
Wed Jan 10, 2007 5:33 am
I have used this to stop the damage..
You need to clean up the area of peeling, I use a power buffer and cutting creme, be very careful not to cut through the existing paint, without clear coat it is very soft! You can buy a can of clear coat, again I go to a paint store and have it made up and put in a can, pressurized, but I think you can buy it at Autozone. Make sure you use a cleaner before you spray. Spray the area affected with the clear coat, allow it to dry for a day or 2 and buff it up. Looks better than you would think, not great, but ok, and will stop the clear coat from continuing to lift..
You have to make sure you have the edges of the clear solid.. peeled back to where it is solid to the paint..
