driverdriver wrote:Welcome to NICO!!!
I would put it up on a hoist and take a good look. If the car drives fine and there are no further symptoms I wouldn't worry about it.
Sounds like the control arm bushings are gone. Very common.craze K wrote:I bought a 94 infiniti J30 and on the way home I hit a bump and there was a bang in the front of the car. Sounded like it hit metal. Do you think it might be a bad strut or shock. My brother pushed on the car and it stopped moving in one bounce so he thought the shocks were ok. The boots on the strut are both torn and just kinda hanging there. What do you think it might be. The springs look ok but the ride seems floaty along with the slam on bumps. Any advice would be good. Thank you, Kim P.S. I'm new to the forum, so hello to all.
I'm taking it to a mechanic on monday to find out what it might need for inspection and such. I'll keep you informed of any repairs needed. Thanks for the advice.gr8scott72 wrote:
Yeah yeah, tension rod, control arm, blah blah.yodawill2000 wrote:Tension rod bearing.It will clank on a bump and if you go about 3 miles an hour and slam on the brake.
Cheap fix if you have a shop with a press nearby.The rod is fine its just the bushing that goes out.
I believe Scott is talking about the same thing.
Control arm , Tension Rod , Tomato Tomahto nuk nuk
