pm_page6776 »
https://forums.nicoclub.com/pm-page6776-u103215.html
Sun Oct 12, 2008 3:29 pm
mixing the fluids is not good, if there is any sign of fluid other than CVT fluid, nissan will not warranty the transmission. Before you panic though, open your hood and check your air intake. Often the tube seperates and causes a lean mixture which feels very much like a transmission issue. If you take it to the dealer, make sure the fluid looks GREEN. Good luck.
