I jumped Timing. Need Help!!!
inlowm523_90tt
Car: 1990 Z32
1990 300zx twin turbo. I have looked into doing the job myself. The driver side idler stud wore its way out and belt slipped off. I caught it in enough time, clamped everything and slipped the belt back on. It is at tdc. I must be on the correct revolution, because the crank mark matches the oil pump case. Marks on passenger side are correct. Marks on drivers side gears are incorrect by about ten teeth. My question is...Can i loosen the tension on the belt and just rotate the driver side gears backwards or forwards to correct position?
nissanfreak12
Car: 92 300zx 2+2 TT
To be honest, I would pull it off and start from the beginning. How you are saying should work, but when it comes to something this touchy and detrimental, I wouldn't risk it. Just remember those timing marks on the back are just for reference. When you get all back on, count the cogs. Double count, after all the proper measurements are done, turn it by hand all the way around make sure nothing hits before starting the car. Any resistance, do not force it. Good luck, we are here to help.
inlowm523_90tt
Car: 1990 Z32
My brother told me i should start over too. Thank you for your help.
es.biggs
Car: 1990 300ZX 5sp NA
Yeah man, take the belt of and start from the beginning, then check compression when you get it running...hope everything works out and no damage was done!
inlowm523_90tt
Car: 1990 Z32
So i did what everyone told me, i took the belt off and started from scratch. Wasn't that bad. I got the belt off and re
installed it in about 1 hour. I thought it was going to be harder than what it was. Thank everyone for their posts about timing belts and ttzd or dallas tx.
300ZXttZMAN
So whats the result?? Good to go??
inlowm523_90tt
Car: 1990 Z32
yeah actually i fixed it... i cant figure out how to post video. I need a wiring harness for a 5 spd twin turbo. Would love to post video
