smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Fri Mar 28, 2008 8:05 pm
Are you getting sound or no? I'm not sure what the power rating on the Bose speakers are, but they are 2 ohm speakers and your double din power output is rated at 4 ohms. 2 ohm speakers present 1/2 the resistance on a system than 4 ohm speakers theoretically, thus they need half the power 4 ohm speakers require (theoretically; 2 ohm speakers also have less clarity, which may be part of the reason the Bose system is terrible). So you could be overpowering them. If you aren't getting sound out of the stock speakers, then you need to bypass the Bose amp. I don't know how its wired or how it is sounding, but those are my 2 pointers right now. But in most cases (100% in my case, I've installed a few myself) when installing a new head unit, you need to bypass the OEM amp so I would lean more towards that one. If that's the case, you need to buy a bypass harness.
If you bought the unit from Crutchfield, call them up, they have great technical service.
