I have some tube that is capped would could it be?
red240sx sr20det
I had this shop do a my swap and I think its my AIC it runs through my intake manifold and is capped, when we first started my car when I got it, it stalled constantly from low RPM's so we adjusted the throttle body im just curious dose this sound right and if so thanks bueller for the hack job.
Taylor_Durdan
pics please or a better desription of where the cap is...
alot of times, when the AIC goes bad, people cap them off and adjust the throttle body stop to set the idle..
slow s13
Car: cars, photo, music
this view is between the 2nd and 3rd intake runners
slow s13
my hose is not stock, so yours will probly be a bit different, the stock setup has a small metal section atached at the green circle on the pic
DarkBlueSr240
yea that looks like where the hose gose so it should come in contact with a metal piece?
slow s13
the hose goes to your intercooler piping
heavy1metal
Car: 1990 240sx
Sort of looks like the radiator hose that leads to the heater core. I have a pin hole leak in that very hose.
Nismo_Freak
Car: 89 Nissan 240SX
Yeah thats the AIV hose.
Try plugging it in and see what happens.
DarkBlueSr240
mine I had to adjust the throttle position so it wouldn't stall but it was plugged when I got my car
Cyberkreig
Car: 1993 Nissan 240SX SR
I have the feeling my iav is f-ed anyway. Maybe this is worth a try.
stiergott
Car: 240
thats where the aiv hose goes. it'll be a ***** to start the car with out that.
DarkBlueSr240
whats the purpose of the hose what dose it do cause like said mine runs now that i adjusted the throttle body.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
It controls extra air at idle. It helps the engine breathe properly at idle. I would hook it up if you can. It will make the car run much smoother.
