I have searched Can't find the info i need. POWER STEERING BELT/PULLEY
GhostRider240sx
Car: 2008 G35x Sedan
Journey
StocK
SO i noticed that i have a 4 rib crank and a 3 rib P/S pulley. The belt i have on there now is 4pk945 which is a 4 ribbed 465mm belt. Gates does not make a 3 ribbed 465mm belt. What do I do. I looked on the stickies, i read all the forums i couldn't find nothing. Someone help me located a 3 ribbed 465 mm belt please.
BoostFab
Car: S13cp, S13fb, S14z
obviously you did not search. look at the stick posts.
zerothread/110509
GhostRider240sx
Journey
StocK
I got the 030328 gates belt, which is tooo short. My pulley is 3 ribs. So i ended up buying a 3-rib which is 37 1/8" so I hope this works other wise I dunno.
Modified by GhostRider240sx at 11:36 PM 2/18/2008
mello88
Car: s13
BoostsFed wrote:obviously you did not search. look at the stick posts.
zerothread/110509
I'll second this. If you searched you would have found my posts on the same topic...
zerothread?id=119087
Except I had 3 rib crank pulley with a 4 rib PS pulley...
You can slot your PS pump tensioner bracket and run a pretty long belt, I ended up with a 3 rib 36.5" belt. a 37 would probably work fine also, I had lots of room left to tension with.
GhostRider240sx
Journey
StocK
The belt I have on there right now is 38" the closest i got was 37 1/8" so I hope that works. Thanx for your suggestion. I was going to slot it. seeing as i dont have a driveway and a garage.. I kinda exhaust all possibilities before going extreme.
mello88
Car: s13
Belts are really cheap too, just buy the next couple sizes up, test fit and return whatever doesn't work
You and I should just trade PS pumps OR crank pulleys, it would make both our lives easier!! LOL j/k.. GL dude...
BoostFab
GhostRider240sx wrote:The belt I have on there right now is 38" the closest i got was 37 1/8" so I hope that works. Thanx for your suggestion. I was going to slot it. seeing as i dont have a driveway and a garage.. I kinda exhaust all possibilities before going extreme.
you can always take your old belt to the store and they will let you eye ball the matching ones.
