95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Wed Dec 07, 2005 8:48 am
probably depends on whether it was a GTR or not. but it is my understanding that all R33's, GTR and GTS/GTS-t, had the R230V rear differential, meaning that no matter how you look at it, the rear end will be too wide to fit in your S13. it would only be a direct swap for the 300ZX-TT. S13/S14/S15/J30/Z32 N/A all use the R200V, which is 200mm wide, versus the R33/R34/Z32-TT's 230mm differential. their wider diff also has a wider case to go with it, which is why it won't bolt up.
in short, get a '95-'96 J30 pumpkin and swap the VLSD and output shafts into your pumpkin. then the pumpkin will bolt up to the car, and the axles will bolt up to the output shafts, and nobody will be the wiser.
