I have nearly given up
RedSubdivisions
Car: 1989 BMW 325i, 2002 BMW 330i
For 6 months now, my 240 has sat at home.
If you've read my previous posts about my car not idling with the MAF plugged in, but does it when it isn't, well...it's still continuing.
I have replaced the following with new(er) parts:
-O2 sensor-Wiring harness-MAF-ECU-IACV (the little blue plug on the backside of the intake manifold-Intake manifold assembly (yes, the whole thing)
Now I'm completely stumped. I have checked for all vacuum leaks and this is a rebuilt motor. In doing so, I have decided to bite the bullet and take her to a shop in a few weeks. before doing so, does anyone have any input or advice for me? This is absolutely mind blowing how small of a problem has costed me a good amount of money.
gnvarnadore
Car: 89 240sx Base Coupe(daily/project) 91 240sx SE Coupe(sold) 92 240sx SE Coupe(sold) 89 240sx Base Hatch(sold) 93 240sx SE Hatch(SOLD!!!)
the best advise i can give you is to have a buddy come look at the car because sometimes a fresh set of eyes can help.
hpmachine
Car: '05 EVO8 + '95 240sx
Simple things first. fuel/air, spark , compression, and it never hurts to check all your fuses.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Sat for 6 months.... drain the fuel, replace the filter, and ad some seafoam and fresh gas and give her a whirl.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
have you checked the timing, tps sensor and or fuel injectors?
LoserCard
Car: Forest Green 1993 240SX SE Fastback
My car had this same problem. I don't know if your symptoms match mine. Mine would start, run perfectly fine for 5-30 seconds and die. It would run crappy without the MAF plugged in. Went through 2 MAFs, 3 Mechanics, countless hours and it turns out all of it was pointless. It was just the ECU. The voltage circuit was faulty.
Get your MAF checked for proper readouts. Get your MAF wiring checked for continuity. Get the MAF circuit in your ECU checked for proper voltage readouts.
I can't promise that it is this exact problem, it just sound very similar to my previous situation.
The point is, instead of replacing things, get things checked.
RedSubdivisions
NISSAN240SX12 wrote:have you checked the timing, tps sensor and or fuel injectors?
TPS, Timing, and Injectors are all tip top shape.
