240tek »
https://forums.nicoclub.com/240tek-u12526.html
Thu Nov 18, 2004 1:25 pm
Thanks for the replies. Ok. About the transmission. Sometimes it will be smooth, but only rarely and that's if I'm holding the clutch and shifting in and out of all the gears, but not letting off the clutch - occasionally one won't knock or bump and just go right in, kind of like it is perfectly lined up after putting the shifter in and out of gear a few times. But yeah, it sounds like a transmission rebuild would be the way to go for that. Secondly, the BIG bang when I press the clutch and pull it out of gear, or depending on speed and rpms going into gear could be solved by doing a rebuild, or at least the problem can be discovered, i.e. if the mount is broken as I suspect. Then the valve cover. Yes one of the bolts is stripped. When I went to replace the gasket one bolt was really easy, where the rest had to be broken loose. Could one lose bolt be the cause of a seep? If so, how can I correct that without replaceing the whole head? Just retap it? Don't know how to do that. About the tune up for the power loss. When I got it I replaced air filter, fuel, plugs, wires, dist. rotor and cap, oil and that's it. I am planning on taking some carb cleaner to the maf and the AIV, although it's a pain to remove. I also ren seafoam through a vacuum line into the intake for about an hour. Is there anything else I could do before I resort to replacing fuel lines or something more drastic? And just to confirm: Today I took it down a parking lot from 3000rpm up to about 5500 or 6. The power was really flat all the way. It really felt like it was lacking. I'm assuming that, while the power of the sohc 240 compared to another car may be lower, it should still feel like it's pulling as hard as it can right? But it doesn't. RPMS are fine and steady but it just doesn't move the car. This is the first 240 I've owned, so I have no point of reference for how this car should behave. Thanks again for all the replies. PEACE. Tek.
Modified by 240tek at 11:38 PM 11/18/2004
