I have gasiline in my oil pan!!!
lilredrocket
Car: 1992 Nissan 240sx Convertible
This happened after I installed new fuel injectors, and didn't realize that the injectors were not seated correctly. The small o-ring was all smushed up and it even took out some of the plastic spacers on the injectors as well. Needless to say, it did not have a good pressure seal, and fuel poured into the cylinders and of course down into the oil pan. I can read about 2.5 to 3 inches over on the dipstick, all due to the extra volatile liquid.
Question, do I need to drain this, replace the oil filter, or can I run on this and dissapate the gasoline that is in there?
Thank you for your time.
Brad H.
Fort Worth, TX
dkdeleon68
Car: 1991 240
Do an oil change. do not drive it with that much gas in the oil because the gas has broken down the oil and you will **** your motor up. So change the oil and filter.Have you resolved the injector leaking problem?
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
def change the oil.
