andrave »
https://forums.nicoclub.com/andrave-u6358.html
Tue Aug 03, 2004 4:09 pm
I'd go with a ka24E.I was in your shoes and I chose to rebuild the DE and turbo it.the DE was a "free" engine that has sucked up all my money, and I learned a few things.first, for management, you can actually use a chip on the sohc ecu. dohc needs the secret service or JWT ecu (both over 500 bucks) to use a chip to tune.second, for parts:on any given day you can find ka24E parts in at least 5 posts in the last week in the for sale section. They are also more plentiful in junkyards (at least in my neck of the woods). DE motors on the other hand, are harder to find, and more expensive once found. Third:parts at parts store are (usually) cheaper for the ka24E. Rebuild parts especially, such as gasket kits, rebuild kits, and especially (ESPECIALLY) the oil pumpfourth:you already have the E in your car. You have all the right stuff. You have the ignition coil, the mafs, the intake piping, the exhaust manifold. The throttle cable, the heater hoses, the radiator hoses. The DE.. um.. do you got all that stuff? Cause I sure as hell don't, and its a problem. One that needs more money thrown at it.and finally:the power steering pump is on the other side of the engine. You either have to make lines, find lines, go with no power steering, or... a mystery option I guess. Also, there is more clearance for a turbo on the DE because of the "no PS pump" thing.
Anyway, if I was doing it again, I'd probably rebuild the ka24E.I would also go with a single turbo.I would also have done a lot more work 2 months ago and probably be driving it already, instead of crying, begging for money, and hoping I get it running in the next week because I may have to park it for a year if I don't.
