Not low enough.BrianHarte wrote:Well, I got a low profile jack. That helps
Sometimes I have to drive onto ramps if I want to use a bigger jack.
Usually I would jack mine up from the differential carrier.
hope you do a write-up for thisAZhitman wrote:Actually, in about a week, I'll just hit a switch and raise the car. Yay.
air jacks?AZhitman wrote:
Not low enough.
I have a pair of super-low profile plastic motorcycle ramps, but even then my front aero hits 'em, so I have to back the front wheels onto them.
Same for the rear.
airbags!red240sx90 wrote:
air jacks?
hahhaMatej wrote:Usually I just keep kicking the jack until it goes under.
I do the same...NICONick wrote: I Just drive up onto wooden planks...
94_240sx wrote:I have a fairly low floor jack, but still it wouldn't go under the frame rail, so this is hwo I do.
- Put a floor jack under the diff and raise- When rear wheels are in the air, slide 2x4 under both wheels- Lower the car- Put a floor jack under frame rail and jack up
mine is to low for me to use tow hooksTimTurboZ wrote:Tow Hooks....
