I have an issue with my car... Can someone please help me?
Discuss topics related to the VQ series engine.
SpecVQ35DE
Car: 2002 Nissan Sentra SE-R Spec V W/VQ35DE Swap, 1990 300ZX TT and 1993 Nissan 300ZX NA
Alrite guys... First time I ever had an issue with my car... About two weeks ago I been driving my Sentra... It has a VQ35DE out of an 03 Maxima. Well I am having gas peddle issues and thought ok livewire... time to replace it... ok after a 30 mins it came back... The peddle was died. Motor ran and what not but the car would not do anything but idle.... Ok so I have spoken to a few people and checked everything from lose grounds, plugs, and wires. I have checked the voltages and what not. With everything on idling "AC, Audio, Lights, Flashers, and everything" It drops to a 10.41v from a 14.2v..... Ok so I believe the ECU is going into Failsafe, but I could be wrong right? Can someone please help me... gettin' sick of this car...
SpecVQ35DE
ok I see that no one is able to help thanks anyways....lol
audtatious
A swap that many have not done. Have you researched this issue via the FSM? If not, here's a link for ya:
http://www.nicoclub.com/FSM/maxima/2003
Q45tech
The ecu has a voltage compensation circuit to fix a little low voltage [cranking, etc] but overall it expects to see 13.2 volts minimum.
With low voltage the injector and individual coil charge time must be longer.
Just use a battery/another car in parallel [jumpers] to bring the voltage up for testing.
jmeister
Car: 1998 Maxima SE
Have you talked to Travis on the vboards? I assume he did the swap. I have no idea how the ECUs are tied in together on that setup. Another reason he needs to share his knowledge.
SpecVQ35DE
Yeah Travis and I have spoke about my car... we figured it's the wiring harness... so Yeah working on it as we speak....
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
