I have an issue
240sxFTW
Car: 89, 240sx coupe
bretjohnson91 wrote:No oil in the intake is a bad sign man i do believe it is your HG the best thing to do is what has been previously posted. Have head and block decks checked and milled if necessary check/replace faulty cooling components. and put on a new HG set and you should be in great running condition in no time.
okay, will do. thanks for the input. And the positiveness haha.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I'll say it again: Do a leak down test, and you will find out EXACTLY what the problem is. If you tear into it to do a head gasket and it turns out to be ring, then your really going to hate life once you get it back together.
240sxFTW
can i find this lead down tester at a local autostore?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Should be able to. When I can't get my hands on one, I hook the hose from my compressor up to my compression tester to see where the air is coming out. It won't give you a leak down percentage, but it does a damn good job of telling you where it is leaking to.
