RCZIII »
https://forums.nicoclub.com/rcziii-u271537.html
Wed Feb 01, 2017 7:11 am
I wasn't trying to go crazy on forged. Just create a TT engine with the N/A block I already have. The heads are the same? Just gotta buy TT cams, TT Rods and wrist pins, TT pistons, TT injectors, standalone system or TT ecu. It might cost more in the long run just spread out over time rather then buying a TT engine. I have a shop I can hone the block after getting it pressure tested. And have heads done at a shop to Have them port and polish and pressure tested and have any word done I need to it. Correct me if I'm wrong but it all should work together. Maybe a new oil pan unless I could just tap and or weld a bung on for oil lines for turbos. Or just do a custom build, with low compression pistons, forged internals and custom grind cams to match?
