C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Mar 28, 2004 3:46 pm
If you are in there , you might consider replacing it anyways.
If you want to unbolt the pressure plate, loosen each bolt a little at a time until pressure is relieved. If the disc, flywheel and pressureplate are still good, you can put it back together, but like I said, I'd go ahead and replace it as long as you are in there, unless the clutch is still very new.
