I have a turbo M30 need a new transmission and I have questions.
speeddocsson
Car: 2006 NIssan Titan,1991 Infiniti M30 vert. TURBO,1969 Datsun 1600 roadster, 1975 Honda CB550 cafe
My 1991 M30 has a low mile 300z turbo motor with low mile on it. When we were tuning the car on the dyno the stock auto transmission wasn't strong enough for all the hp (about 400) or so. So now I need to get a new one. Does anyone know how much horsepower a stock 300z auto transmission car take??I wanna run a auto transmission because I will mostly be dragracing it.
thanks for the help..
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
is it a z31 or z32 trans? what blew up in the trans? and if possible maybe a shift kit and soft different clutches might do the trick.
speeddocsson
its a z31 trans and nothing "blew up" its an auto and its slipping really bad.Do you know how much hp a stock auto trans can take???thanks for the help
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
memory serves its an RE4R01A. I would think with a shift kit you should be able to handle 400HP...
Assume all the fluids are fresh and it was in good shape before you went with terbow powa?
What about a Level 10 rebuild? Wes should have some info on that.
yodawill2000
Car: 94 Infiniti J30
Pics are a must !!!
elwesso
2007 BMW M Coupe
the problem with a rebuild is to do it with an RE4R03A which is what you'd want to do (not sure how beefy you can build a 01A, 400 HP reliably may or may not be in the question) is you'd have to have custom driveshaft made since the 03A has a larger tailshaft, different TC and all kinds of fun stuff
Long story short, if you're gonna go that kind of trouble a 5 speed isnt that much farther off and would be a lot better, and im sure you'd enjoy it a lot more
speeddocsson
Hey greg....Good idea! But my dad gave me the car and my money is limited....and if the stock z transmission can take 400 w/ a shift kit i will probably run that which will be cheaper than the level 10,which I looked into and it would run me about 4grand compared to the stock for like 600... but it nice to here from you on here.....The exhaust on the 200 has been great. Maby ill see you at NOPI this year
speeddocsson
Thanks for the tip Wes...Hope the Q is running well i miss that car.
elwesso
2007 BMW M Coupe
Just be sure, as you probably already know, to run an ATF cooler and good ATF, but more importantly to keep it fresh. Id go ahead and pick up a used 01A trans and get a valve body from IPT or level 10. Personally I prefer IPT over level 10 but to each their own.
the Q has some new shoes since you saw it at NOPI in 2005.
speeddocsson
Wes, i know this is an old thread but i figured i would show you some pics of the m30..... the transmission problem has yet to be decided i am now leaning towards going manual.
here are some pics hope all is well......
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
m30 love<3 solid pearl white<3<3
not as pretty, but 900 dollars :] im preppin' for paint
in regards to your setup..what a cluster screw haha. might i suggest you go and pick up an early maxima intake manifold, where the TB is positioned almost directly in the middle yet pointed towards the rear. lower manifold can be turned 180 since the ports and runners are the same...SHZAM, your TB will be located in the front and not the back of your engine bay.
example on a z31:dthumb
