I'd check the spark plugs, plug wires, distributor cap, ignition coil and rotor. Sounds like a ignition related problem. Make sure the wires are going in the proper order as well along with the firing order. This engine fires in a 1-3-4-2 pattern.NissanPride247 wrote:I got my 89 240 a few months ago and it had been sitting for a couple years. The motor is from a junk yard with about 30 grand on it. It has a bad starting problem. It takes quite a few turn overs and has a rough start. I don't know what it is or what it could be. Some help would be greatly appriciated.
slo_coupe wrote:^^^^^ A leak dow test will be better for valves but if it were valves it would constantly run rough not just on start up. like i said before check for a leaking injector. its a known common issue with ka24e's. dont just throw parts at it either. diag properly to save money and some time.
(Bold Added to above by Vegascorbin)NissanPride247 wrote:I got my 89 240 a few months ago and it had been sitting for a couple years. The motor is from a junk yard with about 30 grand on it. It has a bad starting problem. It takes quite a few turn overs and has a rough start. I don't know what it is or what it could be. Some help would be greatly appriciated.
I would suggest running some Seafoam in the crankcase and the fuel to clean things up a bit. That stuff works wonders on 300ZX's should be just as good on a 240.Nishttp://forums.nicoclub.com/zeropost?cmd=reply&id=3457339"e=1#[URL wrote:zeropost?cmd=reply&id=3457339"e=1#sanPride247]Wow[/URL] thank you. I had check the plugs and wires before I even started the car and they were good. It doesn't have a fuel smell but I will check for wetness in the cylinder. All the ignition stuff looks good. And it runs real smooth once it starts if you look past the slight tick at 2500-3000 rpms. I also ran a compression test and it was perfect in all four. All this info is GREATLY appriciated. You people are the people that makes Nico so great! I will keep this updated as much as possible.
Yeah, it works good in the crankcase in case you got sticky lifters and gunk in it that makes it make noise. Running though the fuel tank will clean out the fuel system of gum, carbon and varnish. I mean dont drive it with it in the crankcase though, its just a flush before you do a oil change and let it idle with it in there to clean everything out.NissanPride247 wrote:The gas was another good question and I did go put about 5 gallons in it. So it was a mix of good gas and crap gas. So maybe when I fill up again it will be better. And I was just talking to a friend that has a 300zx And he sugested seafoam too. So I will give that a shot. Once again thanks for the sugestions all are appriciated.
