chris1212 »
https://forums.nicoclub.com/chris1212-u193723.html
Sat Mar 02, 2013 10:15 am
'[IF SOMEONE SEES A FLAW IN THIS PLEASE TELL ME BEFORE I MESS SOMETHING UP]
Ok the factory radiator fan relay has an normally open set of contacts just like a normal relay. So im thinking those contacts close when your temp gauge goes up. #3 on your relay will energize when the temp moves up. So look under your relay at the plugs and find #3, its printed 1,2,3 and 5. Just hook the power wire from your fans to #3 on the '[HI RADIATOR FAN RELAY] and the second fan wire to a good ground or battery ground. this worked for me and now my fans come on and go off like they should. No after market relay was needed only some wire..If you notice #3 is running to your factory fan plug so you can also tap in at that spot.
I also saw on here some where that your fan should run while your AC is on, witch is true for a real air condition condensor on your house. if not the compressor gets hot, head psi goes up and the unit shuts down. So with that being said, just run a second power wire #3 on your AC relay. I tried this also and my fans come on when the AC button is on along with the inside blower control knob..I also double checked to make sure the fans do not come on in heat mode with the inside control knob. So the fans only work with the AC button+ blower control knob when dealing with the heat and air deal...all of this deletes my purpose of having my aftermarket temp sensor pen hooked to my radiator and making my fans come on when it feels heat. im always having to adjust the controls according to the weather. and most importantly when I park my car the under the hood temp goes up and the fans kept coming on minutes after to cool off everything. that pulls on the battery.
