I have a "shimmy" in the front end at all speeds, can someone confirm my diagnosis?
lbrowne
This gone from noticeable to outright blatant in 2 days.
Theres a shimmy you can feel through the steering wheel and its definitely something in the front end. For those of you who know kind of what a wheel thats not balanced correctly, it kind of feels like that
except,
its at all speeds.
I'm thinking ball joints. My struts are new as of the last several months. Or maybe a tie rod end?
Any ideas? (yes I can feel this in a straight line as well)
ss240
i'm thinking ball joints aswell
p00t
any noise present?
yellow_jacket
Car: 95 240sx
Check your front tires for broken belts or big welts on the sidewalls.
lbrowne
yellow_jacket wrote:Check your front tires for broken belts or big welts on the sidewalls.
after thinking about it again, thats what I'm checking first. because bad ball joints won't do what i'm describin. i've checked with my father and he said the same.
Toast
Try your tension rod bushings. My steering wheel does the same thing and thats the only thing I can see that needs replaced. Mine have cracks in them and can really be noticed when you jack the car up. If this is the case get some whitelines they are the best as far as bushings go IMO.
Camel
Car: That would be obvious....
tc rod bushings. replace with whitelines. best advice from toast. even the ones on my 98 were cracked.
lbrowne
TC rods have been replaced.
Either way the problem is gone completely. I'm guessing that there was ice/snow build up in around one of the rims that unbalanced the wheel...and since it got a lot warmer recently...it fell/melted off.
thnx though fellas. :)
barrigas14
are you on stock rims? if you aren't then it could be that you need some centric (?) spacers for the hubs. my friend had a shimmy with his rims and add those and it went away.
edit++ hub centric or cetric? something along those lines.
