srdrift240 wrote:ok ill check those splices. Wat do u mean control unit? Well im thinkiing that i should ground out the battery to my chassis because right now its only to my block. And i dont think i have a good enough ground. When im drifting i have none of these problems its just when im cruising. i have checked ALL my wires behind my radio.
I took my car up to the shop and they said my pressure plate is going out.
then how did you get your car to the shop?
a control unit is the hub that some electrical gauges will connect to and get their signal from. If all your gauges are doing the same thing then the wiring issue could be at that unit...but if you dont have one then ignore that statement.
And if you have none of these problems while drifting then you should drift everywhere you go.
